[mapguide][MG376][New] Point reference not correctly read when OS uses "," for deci...
Tom Fukushima
tom.fukushima at autodesk.com
Thu Aug 31 12:49:19 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG376
Type
Defect
Artifact ID
MG376 (Point reference not correctly read when OS uses "," for decimal)
Reported by
Tom Fukushima
tomfukushima (tom.fukushima at autodesk.com)
New artifact details:
- Status Explanation set to new value
Many people are experiencing this problem on non-English OSes.
- Developer Notes set to new value
Note that this submission will set the locale of the server to the "C" locale. Previously, the locale of the server was set to the operating system's default locale.
- Steps to Reproduce set to new value
On an OS that uses "," as the decimal point (I used French),
1) Create a point layer and style it as a unfilled circle of size 5mm.
2) Copy the point layer created in 1 but this time style it as a circle of size 1mm.
3) Create a map that contains the two layers.
The small points should be in the center of the larger points, but they are at the lower left. So the insertion points of the symbols are being interpreted as (0,0) when they should be (0.5, 0.5).
- Defect Severity set to new value
High
- Platform set to new value
PC
- Priority set to new value
P1
- Subcomponent set to new value
Rendering Service
- Summary set to new value
- Version set to new value
1.0.1
- Operating system set to new value
All
- Target milestone set to new value
1.0.1
- Artifact created
- Description set to new value
The reference point for point layers is not being read correctly on systems where "," is the decimal point character.
- Artifact Status set to new value
New
- Component set to new value
Server
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
