[mapguide][MG376][Modified] Point reference not correctly read when OS uses "," for deci...
Tom Fukushima
tom.fukushima at autodesk.com
Thu Aug 31 14:09:36 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG376
Type:
Defect
Artifact ID:
MG376 (Point reference not correctly read when OS uses "," for decimal)
Modified by:
Tom Fukushima
tomfukushima (tom.fukushima at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Changed server to run in "C" locale.
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Assigned
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
