[mapguide][MG461][New] JOINS: Default delimiter character when none is specified sh...
Alexander Frumkin
alexander.frumkin at autodesk.com
Fri Dec 1 13:44:34 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG461
Type
Defect
Artifact ID
MG461 (JOINS: Default delimiter character when none is specified should be "" (blank))
Reported by
Alexander Frumkin
frumkia (alexander.frumkin at autodesk.com)
New artifact details:
- Subcomponent set to new value
Feature Service
- Summary set to new value
- Platform set to new value
All
- Steps to Reproduce set to new value
Tux release of MapGuide created feature sources to define joins which did not specify a <AttributeNameDelimiter>. Instead Tux joins always used "", a blank (i.e., nil) character, which resulted in JoinNamePropertyName.
New code is now creating feature sources where an <AttributeNameDelimiter> can be specified, but if it is not the default character is "|" (vertical bar). If this change is brought forward to Bond release ot MapGuide, this will cause incompatibility of Tux feature sources in a Bond server.
- Target milestone set to new value
1.1.0
- Developer Notes set to new value
The default vaue of "|" was replaced with "" in both AttributeRelate constructors
- Submission Reviewed set to new value
Yes
- Version set to new value
1.0.2
- Resolution set to new value
Submitted
- Artifact Status set to new value
New
- External ID set to new value
861752
- Component set to new value
All
- Artifact created
- Description set to new value
This defect was introduced by artifact #MG424 that added a delimiter attribute to the AttributeRelate. Currentyly it has a default value of "|". But is should be "" for backward compatibility.
- Defect Severity set to new value
Medium
- Priority set to new value
P3
- Operating system set to new value
All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
