[mapguide][MG461][Modified] JOINS: Default delimiter character when none is specified sh...
Alexander Frumkin alexander.frumkin at autodesk.com
Fri Dec 1 13:47:27 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG461
Type:
Defect
Artifact ID:
MG461 (JOINS: Default delimiter character when none is specified should be "" (blank))
Modified by:
Alexander Frumkin
frumkia (alexander.frumkin at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
Defect ID MG461: JOINS: Default delimiter character when none is specified should be "" (blank)
Modified
File: trunk/MgDev/Common/MdfModel/AttributeRelate.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/AttributeRelate.cpp?view=diff&rev=1001&p1=trunk/MgDev/Common/MdfModel/AttributeRelate.cpp&r1=1000&p2=trunk/MgDev/Common/MdfModel/AttributeRelate.cpp&r2=1001
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
