[mapguide][MG465][New] CCoordinateSystem::MeasureGreatCircleDistance returns incorr...
Ben Trumbore
ben.trumbore at autodesk.com
Mon Dec 4 18:39:15 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG465
Type
Defect
Artifact ID
MG465 (CCoordinateSystem::MeasureGreatCircleDistance returns incorrect results)
Reported by
Ben Trumbore
bentrumbore (ben.trumbore at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Description set to new value
CCoordinateSystem::MeasureGreatCircleDistance performs a great circle distance calculation for two points specified in the current coordinate system. The current code miscalculates this distance for projected coordinate systems with units other than meters because it performs a distance conversion twice when only one conversion is needed.
- Steps to Reproduce set to new value
This problem was seen in the Hammerhead version of Autodesk Map, when a buffering operation was performed on a layer using a coordinate system with foot units. The same operation worked fine for coordinate systems with meter units or those that were arbitrary or unprojected.
- Defect Severity set to new value
Medium
- Version set to new value
1.0.2
- Summary set to new value
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
