[mapguide][MG467][Modified] Buffer operation fails when polygon or polyline has a near-v...
Bill Dhimitri bill.dhimitri at autodesk.com
Thu Dec 7 14:55:03 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG467
Type:
Defect
Artifact ID:
MG467 (Buffer operation fails when polygon or polyline has a near-vertical segment)
Modified by:
Bill Dhimitri
billdhimitri (bill.dhimitri at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG467
Fix some issues with buffering
Modified
File: trunk/MgDev/Common/Geometry/Buffer/LatLonBorderWalker.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/LatLonBorderWalker.cpp?view=diff&rev=1017&p1=trunk/MgDev/Common/Geometry/Buffer/LatLonBorderWalker.cpp&r1=1016&p2=trunk/MgDev/Common/Geometry/Buffer/LatLonBorderWalker.cpp&r2=1017
File: trunk/MgDev/Common/Geometry/Buffer/pobjbufr.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/pobjbufr.cpp?view=diff&rev=1017&p1=trunk/MgDev/Common/Geometry/Buffer/pobjbufr.cpp&r1=1016&p2=trunk/MgDev/Common/Geometry/Buffer/pobjbufr.cpp&r2=1017
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
