[mapguide][MG469][Modified] Performance improvements for Tile serving
Trevor Wekel
trevor.wekel at autodesk.com
Fri Dec 15 13:47:07 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG469
Type:
Enhancement
Artifact ID:
MG469 (Performance improvements for Tile serving)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG469: Performance improvements for Tile serving
Modified
File: trunk/MgDev/Common/Foundation/Data/NamedCollection.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/Data/NamedCollection.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/Foundation/Data/NamedCollection.cpp&r1=1027&p2=trunk/MgDev/Common/Foundation/Data/NamedCollection.cpp&r2=1028
File: trunk/MgDev/Common/Foundation/Data/NamedCollection.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/Data/NamedCollection.h?view=diff&rev=1028&p1=trunk/MgDev/Common/Foundation/Data/NamedCollection.h&r1=1027&p2=trunk/MgDev/Common/Foundation/Data/NamedCollection.h&r2=1028
File: trunk/MgDev/Common/Foundation/System/StreamHelper.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/System/StreamHelper.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/Foundation/System/StreamHelper.cpp&r1=1027&p2=trunk/MgDev/Common/Foundation/System/StreamHelper.cpp&r2=1028
File: trunk/MgDev/Common/Foundation/System/StreamHelper.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/System/StreamHelper.h?view=diff&rev=1028&p1=trunk/MgDev/Common/Foundation/System/StreamHelper.h&r1=1027&p2=trunk/MgDev/Common/Foundation/System/StreamHelper.h&r2=1028
File: trunk/MgDev/Common/Foundation/System/StreamParser.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/System/StreamParser.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/Foundation/System/StreamParser.cpp&r1=1027&p2=trunk/MgDev/Common/Foundation/System/StreamParser.cpp&r2=1028
File: trunk/MgDev/Common/Foundation/System/StreamParser.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/System/StreamParser.h?view=diff&rev=1028&p1=trunk/MgDev/Common/Foundation/System/StreamParser.h&r1=1027&p2=trunk/MgDev/Common/Foundation/System/StreamParser.h&r2=1028
File: trunk/MgDev/Common/Foundation/System/StreamReader.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/System/StreamReader.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/Foundation/System/StreamReader.cpp&r1=1027&p2=trunk/MgDev/Common/Foundation/System/StreamReader.cpp&r2=1028
File: trunk/MgDev/Common/Foundation/System/StreamWriter.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/System/StreamWriter.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/Foundation/System/StreamWriter.cpp&r1=1027&p2=trunk/MgDev/Common/Foundation/System/StreamWriter.cpp&r2=1028
File: trunk/MgDev/Common/Foundation/System/Util.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/System/Util.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/Foundation/System/Util.cpp&r1=1027&p2=trunk/MgDev/Common/Foundation/System/Util.cpp&r2=1028
File: trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp&r1=1027&p2=trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp&r2=1028
File: trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h?view=diff&rev=1028&p1=trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h&r1=1027&p2=trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h&r2=1028
File: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp&r1=1027&p2=trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp&r2=1028
File: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h?view=diff&rev=1028&p1=trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h&r1=1027&p2=trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h&r2=1028
File: trunk/MgDev/Common/MapGuideCommon/Services/Command.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MapGuideCommon/Services/Command.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/MapGuideCommon/Services/Command.cpp&r1=1027&p2=trunk/MgDev/Common/MapGuideCommon/Services/Command.cpp&r2=1028
File: trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp&r1=1027&p2=trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp&r2=1028
File: trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp&r1=1027&p2=trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp&r2=1028
File: trunk/MgDev/Common/PlatformBase/MapLayer/LayerCollection.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/PlatformBase/MapLayer/LayerCollection.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/PlatformBase/MapLayer/LayerCollection.cpp&r1=1027&p2=trunk/MgDev/Common/PlatformBase/MapLayer/LayerCollection.cpp&r2=1028
File: trunk/MgDev/Common/PlatformBase/MapLayer/LayerCollection.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/PlatformBase/MapLayer/LayerCollection.h?view=diff&rev=1028&p1=trunk/MgDev/Common/PlatformBase/MapLayer/LayerCollection.h&r1=1027&p2=trunk/MgDev/Common/PlatformBase/MapLayer/LayerCollection.h&r2=1028
File: trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp&r1=1027&p2=trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp&r2=1028
File: trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h?view=diff&rev=1028&p1=trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h&r1=1027&p2=trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h&r2=1028
File: trunk/MgDev/Common/PlatformBase/Services/Resource.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/PlatformBase/Services/Resource.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/PlatformBase/Services/Resource.cpp&r1=1027&p2=trunk/MgDev/Common/PlatformBase/Services/Resource.cpp&r2=1028
File: trunk/MgDev/Common/PlatformBase/Services/ResourceIdentifier.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/PlatformBase/Services/ResourceIdentifier.cpp?view=diff&rev=1028&p1=trunk/MgDev/Common/PlatformBase/Services/ResourceIdentifier.cpp&r1=1027&p2=trunk/MgDev/Common/PlatformBase/Services/ResourceIdentifier.cpp&r2=1028
File: trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp&r1=1027&p2=trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp&r2=1028
File: trunk/MgDev/Server/src/Common/Base/ServiceOperation.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Common/Base/ServiceOperation.h?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Common/Base/ServiceOperation.h&r1=1027&p2=trunk/MgDev/Server/src/Common/Base/ServiceOperation.h&r2=1028
File: trunk/MgDev/Server/src/Resources/server_en.res https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Resources/server_en.res?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Resources/server_en.res&r1=1027&p2=trunk/MgDev/Server/src/Resources/server_en.res&r2=1028
File: trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendPlot.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendPlot.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendPlot.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendPlot.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Mapping/OpGenerateMap.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpGenerateMap.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMap.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMap.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Mapping/OpGenerateMapUpdate.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpGenerateMapUpdate.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMapUpdate.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMapUpdate.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Mapping/OpGenerateMultiPlot.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpGenerateMultiPlot.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMultiPlot.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMultiPlot.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Mapping/OpGeneratePlot.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpGeneratePlot.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Mapping/OpGeneratePlot.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Mapping/OpGeneratePlot.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Mapping/OpQueryFeatures.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpQueryFeatures.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Mapping/OpQueryFeatures.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Mapping/OpQueryFeatures.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Mapping/OpQueryFeaturesWms.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpQueryFeaturesWms.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Mapping/OpQueryFeaturesWms.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Mapping/OpQueryFeaturesWms.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Rendering/OpRenderMapLegend.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpRenderMapLegend.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Rendering/OpRenderMapLegend.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Rendering/OpRenderMapLegend.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Rendering/OpRenderTile.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpRenderTile.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Rendering/OpRenderTile.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Rendering/OpRenderTile.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Tile/OpClearCache.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Tile/OpClearCache.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Tile/OpClearCache.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Tile/OpClearCache.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Tile/OpGetTile.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Tile/OpGetTile.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Tile/OpGetTile.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Tile/OpGetTile.cpp&r2=1028
File: trunk/MgDev/Server/src/Services/Tile/OpSetTile.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Tile/OpSetTile.cpp?view=diff&rev=1028&p1=trunk/MgDev/Server/src/Services/Tile/OpSetTile.cpp&r1=1027&p2=trunk/MgDev/Server/src/Services/Tile/OpSetTile.cpp&r2=1028
File: trunk/MgDev/Web/src/mapagent/Resources/web_en.res https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapagent/Resources/web_en.res?view=diff&rev=1028&p1=trunk/MgDev/Web/src/mapagent/Resources/web_en.res&r1=1027&p2=trunk/MgDev/Web/src/mapagent/Resources/web_en.res&r2=1028
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
