[mapguide][MG4][New] Updated makefile.am to fix make install problem
Hartesh Chhabra
hartesh.chhabra at autodesk.com
Wed Feb 22 02:19:32 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG4
Type
OS:Issue
Artifact ID
MG4 (Updated makefile.am to fix make install problem)
Reported by
Hartesh Chhabra
harteshchhabra (hartesh.chhabra at autodesk.com)
New artifact details:
- OS:Component set to new value
Server
- OS:Description set to new value
Vishal pointed out that recent change of provider description caused make install to fail.
Also, cleaned up config.ini file.
1. Changed MapGuide Enterprise to MapGuide Open Source
2. Changed www.autodesk.com to http://www.mapguide.osgeo.org
- OS:Status set to new value
New
- OS:Priority set to new value
P2
- OS:Type set to new value
Task
- OS:Operating System set to new value
Linux
- Artifact created
- OS:Version set to new value
1.0.0
- OS:Target Milestone set to new value
1.0.0
- OS:Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
