[mapguide][MG6][New] More vault cleanup
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed Feb 22 11:55:19 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG6
Type
OS:Issue
Artifact ID
MG6 (More vault cleanup)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- OS:Version set to new value
1.0.0
- OS:Target Milestone set to new value
1.0.0
- Artifact created
- OS:Priority set to new value
P1
- OS:Status set to new value
New
- OS:Type set to new value
Task
- OS:Summary set to new value
More vault cleanup
- OS:Description set to new value
Three changes:
1/ The IMake executable (under BuildTools/WebTools/IMake) was missing from the subversion vault. Either we include the executable, or we add the IMake project to the Oem solution. I spoke with Tim about this and we agreed adding the executable made more sense.
2/ There were still references to FdoUnitTesting in a couple of Makefile.am's. These were removed.
3/ Removed all auto-generated Makefile.in files in the non-Oem area. The vault should only contain Makefile.am files, since the Makefile.in files are generated using automake.
- OS:Platform set to new value
PC
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
