[mapguide][MG7][Modified] Fix SQLite OEM project issues
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Thu Feb 23 15:51:33 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG7
Type:
OS:Issue
Artifact ID:
MG7 (Fix SQLite OEM project issues)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- OS:Resolution set to new value:
Submitted
-- OS:Description set to new value:
Old value:
There were a number of issues with the SQLite projects in OEM:
1/ Many of them were still configured to use the multi-byte character set.  They should all be Unicode.
2/ Many of the projects were written by the MapGuide team, and these need to have the standard header block in all source files.
3/ Many projects still had references to Common folders under "additional include directories".  This is absolutely not allowed for project in OEM.
4/ The Windows sqliteVM project had many problems:
- it was referencing some unicode conversion files under MdfModel - I copied the relevant files to the SqliteVM folder
- the debug configuration did not define SQLITE_EXPORTS
- the project did not have SQLiteDefs.h in its list of files
5/ The SqliteDotNet project had a reference to the ACE libs folder under "additional library directories", but wasn't actually linking to ACE.  Because SqLiteDotNet is built before ACE, this caused a problem since the directory didn't yet exist.  I removed the reference to the libs folder.
New value:
6/ The SQLitePhpAip project had the language.i and SQLitePhpApi.i files checked into the vault.  These are generated as part of the build and should not be checked in.
-- OS:Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
