[mapguide][MG8][New] Fixed failed feature join unit test.
Bruce Dechant
bruce.dechant at autodesk.com
Thu Feb 23 17:02:19 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG8
Type
OS:Issue
Artifact ID
MG8 (Fixed failed feature join unit test.)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- OS:Description set to new value
The server feature join unit test was failing because the test data and comparison fields were not set correctly.
- Artifact created
- OS:Operating System set to new value
All
- OS:Target Milestone set to new value
1.0.0
- OS:Keywords set to new value
Unit test
- OS:Subcomponent set to new value
Feature Service
- OS:Resolution Description set to new value
The code has been fixed.
- OS:Version set to new value
0.9.1
- OS:Component set to new value
Server
- OS:Status set to new value
New
- OS:Priority set to new value
P2
- OS:Platform set to new value
ALL
- OS:Summary set to new value
- OS:Type set to new value
Defect
- OS:Resolution set to new value
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
