[mapguide][MG9][New] Integrate final getting started page set and fix related bug...
Alain Lebatard alain.lebatard at autodesk.com
Thu Feb 23 20:03:16 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG9
Type
 OS:Issue
Artifact ID
 MG9 (Integrate final getting started page set and fix related bug in web surround)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- OS:Type set to new value
  Defect
- OS:Subcomponent set to new value
  Viewer AJAX
- OS:Status set to new value
  New
- OS:Component set to new value
  Viewer
- OS:Priority set to new value
  P1
- Artifact created
- OS:Description set to new value
  The getting started set of HTML pages was missing from this vault.
Also, even though MapGuide open source is not localized, the web surround still needs the localized folder and the 'en' file within, which contains all the strings in English that appear in the UI.
Finally, links to external pages such as www.php.net are broken. The reason is that the gettingstarted.php (.jsp/.aspx) scripts fixup URLs to HTML pages so every page belonging to the getting started is chaneled through this script. The reason for this is mostly to filter out from the command list the commands that are not in use in the curent web layout. Currently the script fixup URLs unconditionally. Instead, it should only fixup URLs to internal pages, and leave the links to external pages unchanged.
- OS:Version set to new value
  1.0.0
- OS:Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
