[mapguide][MG10][New] Attributes for selected feature not listed in certain cases ...
Traian Stanev
traian.stanev at autodesk.com
Fri Feb 24 10:59:24 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG10
Type
OS:Issue
Artifact ID
MG10 (Attributes for selected feature not listed in certain cases (AJAX viewer))
Reported by
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
New artifact details:
- OS:Integration and Build Notes set to new value
Whee!
- Artifact created
- OS:Type set to new value
Defect
- OS:Steps to Reproduce set to new value
See description above.
- os:Status Explanation set to new value
Simple logic error in the QueryFeatures API in the RenderingService
- OS:Target Milestone set to new value
1.0.0
- OS:Status set to new value
New
- OS:Priority set to new value
P3
- OS:Summary set to new value
- OS:Description set to new value
In certain maps, when there are two layers with selectable features, and the user selects a feature on the bottom layer, the attributes for the feature do not show up in the Properties window in the AJAX viewer. If the draw order is switched, the properties do show up.
- OS:Resolution set to new value
Submitted
- OS:Build set to new value
163.8
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
