[mapguide][MG11][New] PHP globalization framework ignores requested locale
Alain Lebatard alain.lebatard at autodesk.com
Fri Feb 24 12:46:16 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG11
Type
 OS:Issue
Artifact ID
 MG11 (PHP globalization framework ignores requested locale)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- OS:Description set to new value
  This works fine for JSP and ASP.NET.
In the PHP web surround, even if a locale other than 'en' is specified in a request using the LOCALE parameter, the framework always uses English.
- OS:Priority set to new value
  P1
- OS:Status set to new value
  New
- OS:Type set to new value
  Defect
- OS:Summary set to new value
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
