[mapguide][MG9][Modified] Integrate final getting started page set and fix related bug...
Alain Lebatard
alain.lebatard at autodesk.com
Fri Feb 24 13:19:57 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG9
Type:
OS:Issue
Artifact ID:
MG9 (Integrate final getting started page set and fix related bug in web surround)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- OS:Status changed:
Old value:
New
New value:
Resolved
-- OS:Resolution set to new value:
Submitted
-- OS:Resolution Description set to new value:
Added the missing getting started HTML files and related styles, images, etc...
Added the file containing the UI text strings for English
In the scripts processing the getting started HTML pages as they are requested, check for links to external pages and do not modify those.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
