[mapguide][MG11][Modified] PHP globalization framework ignores requested locale
Alain Lebatard alain.lebatard at autodesk.com
Fri Feb 24 14:00:49 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG11
Type:
OS:Issue
Artifact ID:
MG11 (PHP globalization framework ignores requested locale)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- OS:Status changed:
Old value:
New
New value:
Resolved
-- OS:Resolution set to new value:
Submitted
-- OS:Resolution Description set to new value:
The existing code didn't even attempt to open the string file correspondig to the requested locale, but instead was directlt falling back to English.
The missing line of code was probably accidently removed before the file was originally submitted.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
