[mapguide][MG12][New] Specifying a center/scale in a web layout may cause the map ...
Alain Lebatard alain.lebatard at autodesk.com
Fri Feb 24 14:15:48 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG12
Type
 OS:Issue
Artifact ID
 MG12 (Specifying a center/scale in a web layout may cause the map not to show)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- OS:Description set to new value
  Specifying a center/scale in a web layout may cause the map not to show.
This problem happens only for JSP.
- OS:Priority set to new value
  P2
- OS:Summary set to new value
- OS:Steps to Reproduce set to new value
  Use the redding data set to create a map with at least one layer in it; I used Parcels.
In the web layout, specify a scale and a center. I used the following values
  scale: 23123
  Center x: 1899433 y: 452411
Open the web layout in a browser with ajaxviewer.jsp, the map doesn't appear. Open the same web layout with ajaxviewer.php or ajaxviewer.aspx, the map appears fine.
- OS:Type set to new value
  Defect
- Artifact created
- OS:Status set to new value
  New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
