[mapguide][MG15][New] More getting started work
Alain Lebatard alain.lebatard at autodesk.com
Fri Feb 24 16:45:32 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG15
Type
 OS:Issue
Artifact ID
 MG15 (More getting started work)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Artifact created
- OS:Priority set to new value
  P2
- OS:Description set to new value
  The final integration of the getting started was not so final. A bug has been fixed in the HTML pages and a new delivery has been made by Tech pubs, which needs to be submitted to the vault.
The fix caused some small HTML format change and require a fix in the gettingstarted scripts
- OS:Status set to new value
  New
- OS:Summary set to new value
- OS:Subcomponent set to new value
  Web API
- OS:Component set to new value
  WebServerExtensions
- OS:Type set to new value
  Defect
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
