[mapguide][MG13][Modified] AJAX viewer uses wrong layer list after turning on/off layer...
Alain Lebatard
alain.lebatard at autodesk.com
Fri Feb 24 16:49:05 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG13
Type:
OS:Issue
Artifact ID:
MG13 (AJAX viewer uses wrong layer list after turning on/off layers)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- OS:Resolution set to new value:
Submitted
-- OS:Resolution Description set to new value:
Force a refresh of the list of visible layers when the visibility of a layer or group changed
-- OS:Status changed:
Old value:
New
New value:
Resolved
-- Value for OS:Subcomponent has been undefined.:
Viewer AJAX
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
