[mapguide][MG15][Modified] More getting started work
Alain Lebatard alain.lebatard at autodesk.com
Fri Feb 24 17:29:17 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG15
Type:
OS:Issue
Artifact ID:
MG15 (More getting started work)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- OS:Resolution set to new value:
Submitted
-- OS:Resolution Description set to new value:
Submitted the latest getting started from Tech Pubs.
Implemented a fix in gettingstarted.php(.jsp/.aspx) to work around a slight change in HTML format.
-- OS:Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
