[mapguide][MG16][New] Java API: Constant classes are generated in wrong package
Alain Lebatard alain.lebatard at autodesk.com
Fri Feb 24 17:32:53 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG16
Type
 OS:Issue
Artifact ID
 MG16 (Java API: Constant classes are generated in wrong package)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- OS:Type set to new value
  Defect
- OS:Description set to new value
  Constant classes are generated in a package named OSGeo.MapGuide. The package name should be org.osgeo.mapguide
- OS:Component set to new value
  WebServerExtensions
- OS:Summary set to new value
- OS:Priority set to new value
  P2
- OS:Subcomponent set to new value
  Web API
- OS:Status set to new value
  New
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
