[mapguide][MG16][Modified] Java API: Constant classes are generated in wrong package
Alain Lebatard alain.lebatard at autodesk.com
Fri Feb 24 19:23:43 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG16
Type:
OS:Issue
Artifact ID:
MG16 (Java API: Constant classes are generated in wrong package)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- OS:Resolution Description set to new value:
IMake was modified to accept a new element <Package> in the input XML file. This allows to distinguish the name of the target package for constant classes on Java, and the target namespace for constant classes on .NET
Constant classes for Java now generated in package org.osgeo.mapguide
-- OS:Status changed:
Old value:
New
New value:
Resolved
-- OS:Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
