[mapguide][MG17][New] AJAX viewer does not initially zoom to map extent
Alain Lebatard
alain.lebatard at autodesk.com
Fri Feb 24 20:49:38 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG17
Type
OS:Issue
Artifact ID
MG17 (AJAX viewer does not initially zoom to map extent)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- OS:Priority set to new value
P3
- Artifact created
- OS:Description set to new value
The AJAX viewer currently applies some black magic calculation to determine the initial view. It should strictly use the map extent instead as does the DWF viewer
- OS:Component set to new value
Viewer
- OS:Type set to new value
Defect
- OS:Subcomponent set to new value
Viewer AJAX
- OS:Summary set to new value
- OS:Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
