[mapguide][MG18][New] Fix tile service unit test
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Feb 24 23:20:31 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG18
Type
OS:Issue
Artifact ID
MG18 (Fix tile service unit test)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- OS:Status set to new value
New
- OS:Component set to new value
Server
- OS:Priority set to new value
P2
- Artifact created
- OS:Subcomponent set to new value
Tile Service
- OS:Version set to new value
1.0.0
- OS:Type set to new value
Task
- OS:Platform set to new value
PC
- OS:Summary set to new value
- OS:Description set to new value
There was a typo in the tile service unit test: one of the data files used by the test had a capitalization error. Under Windows this didn't matter, but under Linux the misnamed data file was not found, and that caused the test to fail.
- OS:Target Milestone set to new value
1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
