[mapguide][MG25][New] Improve MgDisposable debugging info
Walt Welton-Lair
walt.welton-lair at autodesk.com
Mon Feb 27 14:58:33 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG25
Type
OS:Issue
Artifact ID
MG25 (Improve MgDisposable debugging info)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- OS:Platform set to new value
PC
- OS:Type set to new value
Task
- OS:Summary set to new value
- OS:Description set to new value
We have some debug-only code in MgDisposable which checks for concurrent calls to AddRef, Release, and GetRefCount. The original code was simply asserting if a concurrent call was detected. With this change, the name of the class on which the concurrent calls were made is printed out.
- OS:Status set to new value
New
- Artifact created
- OS:Version set to new value
1.0.0
- OS:Priority set to new value
P3
- OS:Target Milestone set to new value
1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
