[mapguide][MG22][Modified] Update Windows RC files
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Mon Feb 27 18:05:24 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG22
Type:
OS:Issue
Artifact ID:
MG22 (Update Windows RC files)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- OS:Description set to new value:
Old value:
The Windows RC files need a couple of updates:
1/ The Company field has been changed to:
"Open Source Geospatial Foundation"
2/ A number of server projects were missing RC files:
- CoordinateSystem
- GwsCommon
- GwsQueryEngine
3/ Many web extensions projects were also missing RC files:
- DotNetUnmanagedApi
- FastCgiAgent
- HttpHandler
- JavaApi
- PhpApi
- WebApp
4/ For the DotNetApi project, I added an AssemblyInfo.cs file
5/ I also noticed that the Makefile for DotNetApi would delete Mg*.cs when doing a clean, which means one of the files it would delete is MgLocalizer.cs.  This file is not generated and should not be deleted.  I therefore renamed it to Localizer.cs.
New value:
- CoordinateSystem
- GwsCommon
- GwsQueryEngine
- FastCgiAgent
- HttpHandler
- JavaApi
- PhpApi
- WebApp
4/ For the DotNetApi project, I added an AssemblyInfo.cs file.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
