[mapguide][MG29][New] Search result list shows URI encoded column titles
Alain Lebatard alain.lebatard at autodesk.com
Mon Feb 27 18:20:53 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG29
Type
 OS:Issue
Artifact ID
 MG29 (Search result list shows URI encoded column titles)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- OS:Status set to new value
  New
- OS:Description set to new value
  The column title in the search result list shows escape sequence for URI encoding. For example a space character is displayed as an escape sequence %20
- Artifact created
- OS:Component set to new value
  Viewer
- OS:Subcomponent set to new value
  Viewer AJAX
- OS:Type set to new value
  Defect
- OS:Steps to Reproduce set to new value
  Create a web layout and add a search command. Define a column in the result list and call it 'The title'. When executing the search command, the result list will display 'The%20title' in the column header
- OS:Priority set to new value
  P2
- OS:Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
