[mapguide][MG30][New] Search result list does not honor max result setting
Alain Lebatard alain.lebatard at autodesk.com
Mon Feb 27 18:24:47 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG30
Type
 OS:Issue
Artifact ID
 MG30 (Search result list does not honor max result setting)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- OS:Description set to new value
  This defect happens only in the JSP implementation of the web surround.
The result list can contain more results that the maximum number of results set in the web layout
- OS:Priority set to new value
  P2
- Artifact created
- OS:Component set to new value
  Viewer
- OS:Status set to new value
  New
- OS:Subcomponent set to new value
  Viewer AJAX
- OS:Type set to new value
  Defect
- OS:Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
