[mapguide][MG30][Modified] Search result list does not honor max result setting
Alain Lebatard
alain.lebatard at autodesk.com
Mon Feb 27 19:04:24 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG30
Type:
OS:Issue
Artifact ID:
MG30 (Search result list does not honor max result setting)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- OS:Resolution Description set to new value:
The argument list in the formatting of the search UI template contained an extra parameter (obsolete), which prevented the match limit setting to be correctly included in the resulting HTML page. The ASP.NET implementation also referenced this obsolete parameter, but did not use it. I just removed the unused reference from the script.
Unrelated to this defect fix: this submission also removes a TODO marker in the server file GwsResourceUtil.cpp. The TODO was a reminder to make sure that the LoadStringW Win32 API is thread safe, which I verified.
-- OS:Status changed:
Old value:
New
New value:
Assigned
-- OS:Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
