[mapguide][MG29][Modified] Search result list shows URI encoded column titles
Alain Lebatard alain.lebatard at autodesk.com
Mon Feb 27 20:14:21 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG29
Type:
OS:Issue
Artifact ID:
MG29 (Search result list shows URI encoded column titles)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- OS:Resolution Description set to new value:
This was a case of double encoding.
The problem is that the column title was encoded with escape() before being put in a form hidden field. At the point, "Street name" became "Street%20Name". Because the form itself is www-url-encoded, "Street%20Name" became "Street%2520Name" on the submission of the form. When the web server received this string, it decoded it to "Street%20Name" which is what appeared in the UI.
The bottom line is that strings put in form should not be encoded for URI.
-- OS:Resolution set to new value:
Submitted
-- OS:Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
