[mapguide][MG37][New] Transparent background for RenderMap doesn't work in case of...
Traian Stanev
traian.stanev at autodesk.com
Tue Feb 28 10:21:50 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG37
Type
OS:Issue
Artifact ID
MG37 (Transparent background for RenderMap doesn't work in case of non-square pixel output)
Reported by
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
New artifact details:
- OS:Steps to Reproduce set to new value
WMS request with TRANSPARENT=TRUE parameter.
- OS:Resolution Description set to new value
Code fixed to keep track of bg color and set it on destination image in case stretch blit is required.
- OS:Keywords set to new value
gd image copy resample transparent
- OS:Type set to new value
Defect
- OS:Component set to new value
Server
- OS:Status set to new value
New
- OS:Platform set to new value
ALL
- Artifact created
- os:Status Explanation set to new value
The resampling call to GD fails to set correct background on destination image.
- OS:Subcomponent set to new value
Rendering Service
- OS:Version set to new value
1.0.0
- OS:Operating System set to new value
All
- OS:Description set to new value
WMS requests which require output image stretch (non-square pixel output) lose their transparent background.
- OS:Priority set to new value
P3
- OS:Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
