[mapguide][MG31][Modified] Cannot select polylines in AJAX viewer
Alain Lebatard
alain.lebatard at autodesk.com
Tue Feb 28 12:35:38 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG31
Type:
OS:Issue
Artifact ID:
MG31 (Cannot select polylines in AJAX viewer)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- OS:Resolution Description set to new value:
The point selection now performs underneath a rectangle selection. The point of click is extended by one pixel in each direction to make a rectangle 3 pixels wide, and this rectangle is sent to the request QueryMapFeatures. The difference between point selection and actual rectangle selection is that the point selection limits the number of requested features to 1.
-- OS:Status changed:
Old value:
New
New value:
Resolved
-- OS:Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
