[mapguide][MG41][New] Each command in the getting started should display an icon
Alain Lebatard
alain.lebatard at autodesk.com
Tue Feb 28 19:31:00 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG41
Type
OS:Issue
Artifact ID
MG41 (Each command in the getting started should display an icon)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- OS:Priority set to new value
P2
- OS:Description set to new value
The command list of the getting started is a definition list made of terms (the command name) and definitions (an explanation on the command).
Each term should include an icon representing the command. The icon URLs should be extracted from the Web layout definition
- OS:Type set to new value
Enhancement
- OS:Summary set to new value
- OS:Status set to new value
New
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
