[mapguide][MG41][Modified] Each command in the getting started should display an icon
Alain Lebatard alain.lebatard at autodesk.com
Tue Feb 28 19:51:51 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG41
Type:
OS:Issue
Artifact ID:
MG41 (Each command in the getting started should display an icon)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- OS:Resolution set to new value:
Submitted
-- OS:Status changed:
Old value:
New
New value:
Resolved
-- OS:Resolution Description set to new value:
The Web layout API code filtering the command list page of the getting started now extract icons for each command, and insert an image tag for it on the left side of each command term
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
