[mapguide][MG330][New] webstudio: select resource dialog double-click not working
Paul Spencer
pspencer at dmsolutions.ca
Wed Jul 5 09:53:10 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG330
Type
Defect
Artifact ID
MG330 (webstudio: select resource dialog double-click not working)
Reported by
Paul Spencer
pagameba (pspencer at dmsolutions.ca)
New artifact details:
- Platform set to new value
All
- Component set to new value
Web Server Extensions
- Artifact created
- Defect Severity set to new value
Medium
- Operating system set to new value
All
- Artifact Status set to new value
New
- Description set to new value
Double-clicking on a resource in the Select Resource dialog closes the dialog but doesn't actually select the resource
- Subcomponent set to new value
N/A
- Priority set to new value
P2
- Steps to Reproduce set to new value
File->New->Layer. Choose a location and name and click ok. In the new layer settings, click '...' to select a feature source for the layer. Navigate to a feature source and double click it. The dialog closes but the feature source is not set in the layer settings. Repeat but single click the resource and click ok and the feature source is set correctly.
There are a number of other places where this dialog is used (add layer to map resource for instance).
- Summary set to new value
- Version set to new value
1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
