[mapguide][MG332][New] MgUnclassifiedException error occurs when the name of the l...
Tom Fukushima
tom.fukushima at autodesk.com
Wed Jul 12 12:28:53 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG332
Type
Defect
Artifact ID
MG332 (MgUnclassifiedException error occurs when the name of the layers in DWF has double-byte characters)
Reported by
Tom Fukushima
tomfukushima (tom.fukushima at autodesk.com)
New artifact details:
- Summary set to new value
- Priority set to new value
P1
- Artifact created
- Steps to Reproduce set to new value
step1. Launch MapGuide Studio.
step2. Create a new folder called DWF.
step3. Drag attached JPNLAYERNAME-model.dwf to DWF folder.
JPNLAYERNAME-model.dwf has the layers which name is double-byte charactersB
step4. Click Save and save the load procedure.
step5. Click Load Resources button.
step6. Expand DWF > Layers folder.
step7. Double-click JPNLAYERNAME-model.
step8. In the Drawing Data Setup area of the Layout Editor, click [...] button.
- Artifact Status set to new value
New
- Description set to new value
- Defect Severity set to new value
Critical
- Platform set to new value
All
- Version set to new value
1.0.0
- Subcomponent set to new value
Drawing Service
- Operating system set to new value
All
- Component set to new value
Server
- Developer Notes set to new value
The enumeratelayers internally was retrieving an ascii string for the layer name. I tried to change the code to retrieve the unicode form of the string, and it fixes the exception problem. The characters still display as in the DWF viewer, but at least there's no exception.
- Added file attachment
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
