[mapguide][MG338][New] Support custom SWIG wrappers for .Net
Trevor Wekel trevor.wekel at autodesk.com
Thu Jul 20 18:28:27 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG338
Type
 Enhancement
Artifact ID
 MG338 (Support custom SWIG wrappers for .Net)
Reported by
 Trevor Wekel
 trevorwekel (trevor.wekel at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Target milestone set to new value
  1.1.0
- Priority set to new value
  P2
- Artifact created
- Documentation Notes set to new value
  Autogeneration of documentation for custom wrappers is desirable.  An appropriate mechanism should be discussed.
- Summary set to new value
- Justification set to new value
  This functionality allows for language specific extensions to the wrappers such as .Net collection support, and casts to/from fundamental .Net data types.  When the language extensions are written, the APIs appear to be more ".Net native" and more usable.
- Description set to new value
  Modify SWIG generation routines to insert custom code into the generated .Net wrapper classes.  If a file with the same name as the class is present in the DotNetUnmanagedApi/custom directory then the code contained in the file is emitted into the generated wrapper.
- Submission Reviewed set to new value
  No
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
