[mapguide][MG339][Modified] Fix gcc 4.1 build errors
Traian Stanev traian.stanev at autodesk.com
Thu Jul 27 11:42:23 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG339
Type:
Enhancement
Artifact ID:
MG339 (Fix gcc 4.1 build errors)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG339 : Fix gcc 4.1 build errors
Modified
File: trunk/MgDev/Common/MdfModel/ChannelBand.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/ChannelBand.h?view=diff&rev=722&p1=trunk/MgDev/Common/MdfModel/ChannelBand.h&r1=721&p2=trunk/MgDev/Common/MdfModel/ChannelBand.h&r2=722
File: trunk/MgDev/Common/MdfModel/GridColor.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/GridColor.h?view=diff&rev=722&p1=trunk/MgDev/Common/MdfModel/GridColor.h&r1=721&p2=trunk/MgDev/Common/MdfModel/GridColor.h&r2=722
File: trunk/MgDev/Common/MdfModel/GridColorRule.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/GridColorRule.cpp?view=diff&rev=722&p1=trunk/MgDev/Common/MdfModel/GridColorRule.cpp&r1=721&p2=trunk/MgDev/Common/MdfModel/GridColorRule.cpp&r2=722
File: trunk/MgDev/Common/MdfModel/GridColorRule.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/GridColorRule.h?view=diff&rev=722&p1=trunk/MgDev/Common/MdfModel/GridColorRule.h&r1=721&p2=trunk/MgDev/Common/MdfModel/GridColorRule.h&r2=722
File: trunk/MgDev/Common/MdfModel/GridColorStyle.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/GridColorStyle.cpp?view=diff&rev=722&p1=trunk/MgDev/Common/MdfModel/GridColorStyle.cpp&r1=721&p2=trunk/MgDev/Common/MdfModel/GridColorStyle.cpp&r2=722
File: trunk/MgDev/Common/MdfModel/GridColorStyle.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/GridColorStyle.h?view=diff&rev=722&p1=trunk/MgDev/Common/MdfModel/GridColorStyle.h&r1=721&p2=trunk/MgDev/Common/MdfModel/GridColorStyle.h&r2=722
File: trunk/MgDev/Common/MdfModel/GridScaleRange.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/GridScaleRange.cpp?view=diff&rev=722&p1=trunk/MgDev/Common/MdfModel/GridScaleRange.cpp&r1=721&p2=trunk/MgDev/Common/MdfModel/GridScaleRange.cpp&r2=722
File: trunk/MgDev/Common/MdfModel/GridScaleRange.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/GridScaleRange.h?view=diff&rev=722&p1=trunk/MgDev/Common/MdfModel/GridScaleRange.h&r1=721&p2=trunk/MgDev/Common/MdfModel/GridScaleRange.h&r2=722
File: trunk/MgDev/Common/MdfModel/GridSurfaceStyle.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/GridSurfaceStyle.h?view=diff&rev=722&p1=trunk/MgDev/Common/MdfModel/GridSurfaceStyle.h&r1=721&p2=trunk/MgDev/Common/MdfModel/GridSurfaceStyle.h&r2=722
File: trunk/MgDev/Common/MdfModel/HillShade.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/HillShade.h?view=diff&rev=722&p1=trunk/MgDev/Common/MdfModel/HillShade.h&r1=721&p2=trunk/MgDev/Common/MdfModel/HillShade.h&r2=722
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
