[mapguide][MG341][New] Print outs have incorrect scale
Andrew andrew.demerchant at gemtec.ca
Thu Jul 27 13:43:03 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG341
Type
 Defect
Artifact ID
 MG341 (Print outs have incorrect scale)
Reported by
 Andrew
 andrew_demerchant (andrew.demerchant at gemtec.ca)
New artifact details:
- Description set to new value
  If you select a printout to be at a specific scale, it's wrong (off by about 5%).
- Summary set to new value
- Artifact Status set to new value
  New
- Steps to Reproduce set to new value
  If you are using a custom print layout with a scalebar, it's easier to notice right away. Print something at 1:10000, for example. Then grab an actual 1:10000 scale and you'll see that the scale bar on the page is too small. From 0 to 600 metres, it should measure 60mm, but is actually only 56mm. This translates to a 40metre error when scaling things off of the printout. The scalebar does actually match the scale of the drawing though, but it is not 1:10000, as it claims.
- Version set to new value
  1.0.1
- Subcomponent set to new value
  DWF Viewer
- Component set to new value
  Viewer
- Artifact created
- Platform set to new value
  PC
- Defect Severity set to new value
  Medium
- Operating system set to new value
  Windows 2000
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
