[mapguide][MG343][New] Refactor Common Service code base to facilitate use in other...
Trevor Wekel trevor.wekel at autodesk.com
Fri Jul 28 19:08:19 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG343
Type
 Enhancement
Artifact ID
 MG343 (Refactor Common Service code base to facilitate use in other applications)
Reported by
 Trevor Wekel
 trevorwekel (trevor.wekel at autodesk.com)
New artifact details:
- Developer Notes set to new value
  This is an initial submission that will coexist with the current development tree.  Additional submissions will be make to port existing MapGuide functionality to use the new infrastructure.  Since MapGuide will not compile with these new projects, there are used when building the Server or Web Extensions.
- Summary set to new value
- Artifact created
- Integration and Build Notes set to new value
  No changes to the build process are required for now.
- Priority set to new value
  P2
- Target milestone set to new value
  1.1.0
- Artifact Status set to new value
  New
- Description set to new value
  Refactor the common Service project so portions of it can be reused in other applications.  These other applications will have different implementations of the various Services.
This drop of the code base refactors a significant portion of the code base and allows ResourceService and FeatureService to be implemented in an application specific manner.
- Submission Reviewed set to new value
  No
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
