[mapguide][MG343][Modified] Refactor Common Service code base to facilitate use in other...
Trevor Wekel trevor.wekel at autodesk.com
Fri Jul 28 19:24:31 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG343
Type:
Enhancement
Artifact ID:
MG343 (Refactor Common Service code base to facilitate use in other applications)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution Description set to new value:
Code submitted
-- Status Explanation set to new value:
Initial code drop submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
