[mapguide][MG304][Modified] GLOB: Overlapped text in "Create a Buffer" pane
Alain Lebatard
alain.lebatard at autodesk.com
Fri Jun 2 13:12:32 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG304
Type:
Defect
Artifact ID:
MG304 (GLOB: Overlapped text in "Create a Buffer" pane)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Adding non breakable space around the string is enough so it doesn't look truncated
-- Target milestone set to new value:
1.0.1
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
