[mapguide][MG305][New] GLOB: Hard Coded String, 'Measure'
Alain Lebatard
alain.lebatard at autodesk.com
Fri Jun 2 13:19:49 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG305
Type
Defect
Artifact ID
MG305 (GLOB: Hard Coded String, 'Measure')
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
1. Open any web layout specifying LOCALE=ja
2. Start a measure command and click the first 2 points on the map
=> Layer in the legend control is named 'Measure'
- Priority set to new value
P3
- Version set to new value
1.0.0
- Subcomponent set to new value
Viewer Command
- Defect Severity set to new value
Medium
- Description set to new value
The name of the layer created for a measure is hardcoded to 'Measure'. It should be localizable.
- Artifact created
- Summary set to new value
- Component set to new value
Web Server Extensions
- Artifact Status set to new value
New
- Platform set to new value
All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
