[mapguide][MG305][Modified] GLOB: Hard Coded String, 'Measure'
Alain Lebatard
alain.lebatard at autodesk.com
Fri Jun 2 13:47:09 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG305
Type:
Defect
Artifact ID:
MG305 (GLOB: Hard Coded String, 'Measure')
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Load at runtime the localized measure layer name
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
