[mapguide][MG306][New] GLOB: Localized string 'Tasks' is truncated due to hard code...
Alain Lebatard alain.lebatard at autodesk.com
Fri Jun 2 14:20:22 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG306
Type
 Defect
Artifact ID
 MG306 (GLOB: Localized string 'Tasks' is truncated due to hard code width size.)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Component set to new value
  Web Server Extensions
- Artifact created
- Subcomponent set to new value
  General
- Defect Severity set to new value
  High
- Platform set to new value
  All
- Summary set to new value
- Priority set to new value
  P2
- Steps to Reproduce set to new value
  1. Open Sheboygan sample file with either DWF or AJAX viewer.
2. Add locale parameter at the end of URL (e.g. &LOCALE=ja).
Problem: Tasks button description is truncated and cannot be adjusted (right pane of viewer)
- Description set to new value
  The text of the tasks button is truncated in non-English versions because the size of the button is hardcoded fo the length of the English text
- Version set to new value
  1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
