[mapguide][MG269][Modified] MapGuide service has underlying name "Server", conflicting w...
Bruce Dechant
bruce.dechant at autodesk.com
Fri Jun 2 16:29:43 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG269
Type:
Defect
Artifact ID:
MG269 (MapGuide service has underlying name "Server", conflicting with the netsvcs(LanManServer) service.)
Modified by:
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
The following modifications were made to this artifact:
-- Steps to Reproduce set to new value:
Old value:
1. Open the MMC Services Snap-in
2. Ensure that the MapGuide Server service is running
3. Open a command window
4. Issue the command NET STOP "MapGuide Server"
5. Note that the display echos "The Server service is stopping"
6. Refresh the MMC screen, and note that the MapGuide Server service is still running, and the Server service has stopped
New value:
-- Target milestone set to new value:
1.0.1
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Priority set to new value:
P3
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
