[mapguide][MG306][Modified] GLOB: Localized string 'Tasks' is truncated due to hard code...
Alain Lebatard alain.lebatard at autodesk.com
Fri Jun 2 18:52:33 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG306
Type:
Defect
Artifact ID:
MG306 (GLOB: Localized string 'Tasks' is truncated due to hard code width size.)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Size and position of the task button now derives from actual text metrics.
-- Target milestone set to new value:
1.0.1
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
