[mapguide][MG308][New] Ajax Viewer Tooltips and other requests fail when MapAgent i...
Trevor Wekel
trevor.wekel at autodesk.com
Fri Jun 2 19:43:34 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG308
Type
Defect
Artifact ID
MG308 (Ajax Viewer Tooltips and other requests fail when MapAgent is run as regular CGI)
Reported by
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
New artifact details:
- Subcomponent set to new value
Map Agent
- Version set to new value
1.0.0
- Target milestone set to new value
1.0.1
- Steps to Reproduce set to new value
Configure the MapAgent as a regular CGI process under Apache. Load Sheboygan in the Ajax Viewer and zoom to the parcels. Hover over one of the parcels. Tooltips are not displayed.
On Linux, most HTTP requests will fail, eg. ENUMERATERESOURCES.
- Artifact created
- Submission Reviewed set to new value
No
- Platform set to new value
All
- External ID set to new value
793583
- Developer Notes set to new value
This defect was caused by some errant code in the MapAgent shutdown mechanism.
- Description set to new value
The MapAgent cannot be run as a regular CGI on Apache or IIS. Configuring as CGI leads to system instability.
- Operating system set to new value
All
- Priority set to new value
P2
- Summary set to new value
- Artifact Status set to new value
New
- Component set to new value
Web Server Extensions
- Defect Severity set to new value
Medium
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
