[mapguide][MG308][Modified] Ajax Viewer Tooltips and other requests fail when MapAgent i...
Trevor Wekel trevor.wekel at autodesk.com
Fri Jun 2 19:47:51 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG308
Type:
Defect
Artifact ID:
MG308 (Ajax Viewer Tooltips and other requests fail when MapAgent is run as regular CGI)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
-- Status Explanation set to new value:
Code fix submitted.
-- Resolution Description set to new value:
Code fix submitted.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
