[mapguide][MG296][Modified] Define Search Command using Like $USER_VARIABLE doesn't work
Trevor Wekel trevor.wekel at autodesk.com
Mon Jun 5 12:12:55 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG296
Type:
Defect
Artifact ID:
MG296 (Define Search Command using Like $USER_VARIABLE doesn't work)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Submission Reviewed set to new value:
Yes
-- Review Comments set to new value:
Ok.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
